New Porsche Owner (964)
Looking for Mechanic for 964 in Tampa
Hello - Does anyone have a recommendation for a good 964 mechanic in the Tampa area? I have a 91 and at this point just need the rear brakes replaced and could do it myself but I'm just thinking I should stick to what I do and let them do what they do! If anyone has a link to a thread for replacing them that would be appreciated as I do have the brakes and all the tools.....
There's probably a few other maintenance things to have them look at as well. I've had the car for almost a year now and have primarily just enjoyed it instead of breaking it down and rebuilding it before truly understanding the joys of cruising in it with the top down! I'm not neglecting maintenance either as I've probably only put 1000 miles on it but I do want to keep up with it....
Thanks!
Old 10-21-2008, 02:42 PM
Shops
Call Frank Eibel, Eibel Performance he is on the other side of the bridge but does good work, tell him Mike Bruns sent ya !
Mike
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 10-22-2008, 07:09 AM
Thanks! I gave him a call and definitely a good guy with what definitely is an appreciated outlook on some of the repairs I may or may not need (cam cover seals...)! He had good words about you as well Mike but hopefully I don't need your services (engine rebuilding) too soon!
Thanks again!
In case anyone else ends up looking for the same info - it's Eibell Performance 727-573-0911 and eibell.com
Old 10-22-2008, 07:20 AM
Frank
Thanks, he has been doing this for a long time and will treat you well
Mike Bruns JBRacing.com
Old 10-28-2008, 11:14 AM
