'91 C2 Cab
Factory Wheel Locks '91 964
Got a simple question,
Are the factory wheel locks on a '91 964 sized differently in length for the front wheels verses the rear? I have the stock D90 wheels on the car.
I bought a set of original Porsche locks, but come to find out they were from a 944. The locks extend out at least a quarter of an inch further than the face of the front wheel, they are recessed just fine for the rear wheels.
I find it hard to believe Porsche would design the front wheel locks this way.
'91 C2 cab 50K miles box stock, driver, just not daily.
"I never cease being dumbfounded by the unbelievable things people believe."
Leo Rosten
Old 12-12-2008, 01:38 PM
Member
Yes, the factory locks are the same for the front and rear.
I changed to aftermarket locks with a black plastic cover,
they are recessed, look stock, and dont protrude in the front.
Paul
91 964 C2 Targa sold (shipped back to the fatherland)
09 Cayman PDK 17 Titan
55 Sunbeam S7 Deluxe
70 Triumph Bonneville
Old 12-12-2008, 02:08 PM
'91 C2 Cab
Do you still have your original ones?
Leo Rosten
Old 12-12-2008, 03:53 PM
Manassas, VA
lucittm's Avatar
Hans,
If your car is a "garage queen" and has stock wheels, why don't you ask your friendly Porsche mechanic to give you four stock lug nuts and forget about the wheel locks?
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 12-13-2008, 09:57 PM
'91 C2 Cab
Originally Posted by lucittm View Post
Hans,
Mark
I have stock lug nuts, I am just trying to equip my car with the way it came from the factory. Completely original equipment all the way around right down to those wheel locks.
Leo Rosten
Old 12-14-2008, 12:36 PM
Manassas, VA
lucittm's Avatar
Hans,
My '91 is stock as well with the exception of an updated radio/changer in the luggage compartment, some updated Alpine speakers in the original size/location, and a K&N filter attached to a 930 style air snorkle. I also deleted the aux air injection system and the catalytic converter. Recently, I upgraded the DMF for a lightweight flywheel and Turbo S clutch disk, retaining the original crank sensor and pressure plate. In the process of this engine drop, I replaced about 20 missing original engine compartment bits and pieces.
So I am completely with you.
Unless your car has option M455, the wheel locks were likely added at a later date by a previous owner. Some dealerships just put them on and then charged the buyers another $250 on the sticker. Your front cover should have the sticker showing the options.
Thanks,
Mark
Old 12-14-2008, 05:34 PM
'91 C2 Cab
Hans,
Thanks,
Mark
Great information, thank you. I will look for the M455 option code. I suspect something else was there at some point because each wheel has one newer lug nut in place.
My C2 is completely original, right down to the radio which admittedly leaves a bit to be desired for pure sound quality. I just leave it off and listen to the best music there is; the sound of that sweet flat six behind me.
Leo Rosten
Old 12-15-2008, 04:41 AM
Member
Yes, i have the original locks, complete with the little black plastic covers and key.
If you decide to use them, email me an offer!
paul@gizmofixer.com
Paul
Old 12-15-2008, 12:08 PM
