-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   I Have A Trunk Release Issue (http://forums.pelicanparts.com/porsche-964-993-technical-forum/446538-i-have-trunk-release-issue.html)
lucittm 12-15-2008 01:37 PM
There is a cover over the luggage compartment (trunk) release lever. Mine broke at the mounting points. I ordered a new one from our host and when it arrived, I saw that it mounted in a completely different way. The part number is the same and it's molded right into the piece.
lucittm 12-15-2008 01:41 PM
Here is the picture:
My OEM unit has little fingers that spread out when the screw is turned; like a moly bolt.
The replacement uses locating rings and, most likely, longer screws that reach into a threaded part that I don't have. This must be a new design since the mounting boss is much more robust (But it has the same P/N)!
Does anyone have one of these covers that they no longer need? It has to have the little fingers like the one on the right.
http://forums.pelicanparts.com/uploa...1229377267.jpg
Thanks,
Mark
Don Plumley 12-16-2008 09:09 AM
You might try asking over on the track board too - someone that has ditched the factory setup for hood pins.
