1989 964 C4
89 C4 intermittent electrical problem
I have been having an intermittent problem with the electrical system. I start the car up fine. I let it idle and warm a little then back out of the garage. Sometimes it just turns off. I try to start it again and the instrument cluster is dark when I turn the key. No sounds from the starter. Then I wait 30 min and the car starts fine. I has done this about 4 times in the last month. I had the battery changed and a faulty mirror switch changed as well. I am wondering if it is an alternator problem or maybe the DMU.
Thanks for your help Cons
_________________ 1989 911 C4 |
sounds like a corroded or poor battery connection or bad ground, either at the trans to body strap or the battery to body strap. check the starter connection while you're at it.
1989 964 C4
Thanks I will check it out.
