993 Front Bumper Removal
Well, I've done the searches but not found exactly what I need. Could someone outline just what's involved in removing my '98 993 front bumper for paint? What are the pittfalls? Seems to me that I've read somewhere that there are some tabs that can break. Any advice for me? And, is there anything to watch out for when reinstalling?
Any help would be greatly appreciated.
Thanks in advance,
Scott
Old 11-29-2008, 06:03 PM
Don Plumley's Avatar
Here you go: DIY
Don Plumley
M235i
Old 11-29-2008, 08:57 PM
Exactly what I needed! Thanks so much.
Scott
Old 11-29-2008, 09:15 PM
maxnine11's Avatar
While you have the front bumper off:
-clean the oil cooler radiator (passenger side)
-clean the a/c condensor (driver side)
-replace the ballast resistor for each of the above.
max
Old 11-30-2008, 12:42 PM
jhubs's Avatar
This is a very easy job. The most difficult part is removing the front part of the fender liner. The first time I removed the bumper it took a couple of hours..the last time, 15 minutes. Follow Don Plumley's advice and go to the DYI website...that is where I started. Print the photos and head for the garage!
Good advice to replace the ballast resistors while you are in there. The Pass. side is easy when the bumper is off. The Driver's side is a total PITA no matter what you do. Get the proper size allen wrench and grind off the short end down to about 1/2 inch long and buy a box of bandaids.
Have fun!
1995 993 Carrera, Guards Red Coupe (current)
1987 911 Carrera, Marine Blau Metallic (06-08) Gone but...
1965 Yellow Mustang Convertible (65-05)
__________________________________________
It is always a good idea to keep the pointy end going forward as much as possible.
Old 11-30-2008, 08:54 PM
RandyF's Avatar
Does anyone know how well the DIY applies to a 964? I need to replace the oil cooler on the front right of mine.
...Randy
90 964 - Weekly Driver
2003 Celica - Daily Driver
78 911 SC - SOLD
Old 01-29-2009, 11:36 AM
yel911's Avatar
Are there any threads to rear bumper cover removal? I need to do both.....
74' 911 w/3.2L (sold)
95' 993 C2 Triple Blk Cab.
02 Honda Superhawk (sold)
2018 Toyota Tundra Limited
2004 CRF250X
Old 02-05-2009, 08:54 AM
