Help with 993 wheel alignment
I have just put on PSS10 and TRG sways front and rear. I will be doing DEs and driving on the street. I am looking for height setting and alignment setting that will satisfy both. I know that does not really happen, but what have you done and what are the down falls and advantages?
Thanx Rob
96 993 NB
Old 12-23-2008, 03:10 PM
Bill Verburg's Avatar
here's the factory specs
here's some i've used
unless you also use RS uprights stay above factory RS height
Bill Verburg
Old 12-24-2008, 05:25 AM
cgfen's Avatar
Thanx Rob
96 993 NB
i have a 96 WB with 10's and TT anti-sways i use for Street and TT
Front = -2.1 degrees camber
Rear = -2.0 degrees camber
Essentially 0 front toe
Don't remember rear toe, sorry, but i also installed ERP rear toe links and had K toe set.
Ride height = RS + 2 - 3mm
i run 235 front and 295 rear with no rubbing issues at this height.
All alignment work done by Jae Lee @ Mirage in San Diego.
I'm very happy thus far.
I'm now driving a car that is "transformed".
Previously an undrsteering AWD "pig", it now turns in very nicely and i can get the car to rotate ,( pitch-n-catch).
if this is too much camber for the street and wears tires a bit more quicky......... no big deal
it is a bit more "twitchy" to drive on the fwy and tends to follow the road contours more readily (tramline), again............. no big deal
I'm very happy with this setup.
Craig
Old 01-05-2009, 10:26 AM
Originally Posted by cgfen View Post
.....it is a bit more "twitchy" to drive on the fwy and tends to follow the road contours more readily (tramline), again.............
Craig
A small amount of toe goes a long way toward eliminating that
Bill Verburg
Old 01-05-2009, 11:08 AM
Hey Bill- Toe in to eliminate the twitch? I'm having a similar issue with my 930. See post in 930 area. Interested to hear what you think. Thanks, Jeff
Old 01-06-2009, 09:32 AM
Thanx for all the info. I had my car corner balanced and aligned today. I review everyone's recommendations with my mechanic. I'll post what he did.
Thanx again.
Rob
Old 01-06-2009, 03:39 PM
OK I have my car back. What a difference.
96 993 NB
I just put PSS10 all around, TRG front sway, H&R rear sway.
235/45/17 and 275/40/17
Front:
Camber - -2.15
Caster - 5.35
Toe - 0.01
Rear:
Camber - -1.59
Toe - 0.17
Corner balanced
Front:
L - 591 R - 585 38.8%
Rear:
L - 923 R - 931 61.2%
Hope to do my first DE of the year next month.
Thanx again Rob
Old 01-09-2009, 04:34 PM
