ABS fuse where?
I would like to remove the fuse for a day and see what difference it makes in the snow we are having in the UK just now.
Dry conditions are something else again, and I very much like having all the help I can get, but this evening on a slippery road and at a walking pace.... it got away from me and slid into the kerb does anybody know the fuse number off hand obviously I'll check before removing it, just trying to spend a little less time in the dark looking for it. thanks |
IIRC, the ABS fuse also disables the speedometer...
Ahh,
still not the end of the world, although there wouldn't be a rear spoiler popping up at 50' not very likely to reach that speed anyway+ the speedo would make a handy reminder to pug it all back in again next week, don't suppose you happen to know which one (or colour) it is do you? |
No, I don't remember for sure it was a year or two ago that I had the issue of a blow fuse and no speedo and ABS. It was clearly indicated on the fuse "map" on the inside of the fusebox lid. IIRC it was in the row closest to the windshield and a 10 amp fuse (I want to say #14).
Thanks for that,
if it all goes quiet (just leave YOUR fuse where it is) |
Just pull out the ABS relay.
| All times are GMT -8. The time now is 11:44 AM. |
