P911
rswartz's Avatar
Ignition Switch
Could anyone tell me how to replace the ignition switch control (This is the unit that mounts behind the key) of my Porsche 964?
Thx for the help
Rob
Old 02-24-2009, 12:59 AM
group911@aol.co's Avatar
They unscrew if that's what you are asking. Not sure on a 964 if you have to pull the whole thing to get to it.
Thanks,
Bob
group911@aol.com
Old 02-24-2009, 10:09 AM
kurquhart's Avatar
If we are talking about the same part, it is mounted with bolts that have a break off head to reduce theft. You need to grind the remaining part of the bolts off to remove.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 02-24-2009, 01:00 PM
P911
rswartz's Avatar
Thanks for thr advice.Gonna try it this weekend and let ye know.
Grtz
Rob
Hello To All
Renault Clio (city car)
Porsche Carrera coupé 1991
Chevrolet Silverado 2500 HD Duramax / Diesel
http://s241.photobucket.com/albums/ff153/rpswartz/
Old 02-25-2009, 08:56 AM
Are you talking about the electrical switch or the key lock? The lock is bolted in with break away screws but the actual electrical switch behind the lock mechanism is held in place by two simple screws. Changing the switch is actually very easy once you get to it behind the dash. you need to remove a couple of pieces and take the left vent grille off to get to the switch - you also need some band aids
'91 C2 Targa
Old 02-27-2009, 08:13 AM
P911
rswartz's Avatar
Hello Cjoenck,
It's the electrical switch. I have to pull off the wire connector from that switch.
But then, i think the bottom screw is easy? , but the top screw
how to get there ? Do i need a special tool, is there a secret to get to that screw?
Grtz
Rob
Hello To All
Old 02-27-2009, 10:12 AM
you take the whole assembly out and then swap the switch.
206 637 4071
Old 02-27-2009, 04:53 PM
Metal Guru
911nut's Avatar
Take out the seat:
Lay on your back with you head under the dash.
Remove this module:
Now you can see and reach the switch.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 02-28-2009, 03:18 AM
Metal Guru
911nut's Avatar
Now unplug the harness from the back of the switch. The switch will look like this:
There's a hole in the knee bolster below the switch. Put a piece of tape over it so you don't lose the screw from the switch in it. Now take the two screws out and remove the switch.
Paul B.
'91 964 Turbo
Old 02-28-2009, 03:24 AM
Metal Guru
911nut's Avatar
When you look at the back of the switch you will notice that it will only install in one orientation.
Installation is the reverse of removal.
To John Walker's point, it's usually not the switch that goes bad; it's the tumbler mechanism getting contaminated from the key and wearing out that causes the problems. Try shooting some WD-40 into it and then stick the key in, pull it out and wipe it off about 30 times to get the debris out of it. This technique improved the function of my tumbler.
Paul B.
'91 964 Turbo
Old 02-28-2009, 03:29 AM
P911
rswartz's Avatar
Porsche Crest
Hello 911nut,
It took a while , but excatly as you described,today i replaced the ignition switch.It took a little hour but then it was fixed .
Thanks again for your clear explanation in words and pic's
Thks
Rob
Hello To All
Old 05-13-2009, 10:41 AM
Does the electrical connector just pull straight off?
I'm replacing the electric part of the ignition switch and am afraid I'll mess up the connector. Does it just pull straight back off of the pins?
Old 06-13-2014, 05:04 PM
JPP JPP is offline
JPP's Avatar
Yes .. I used a plastic trim removing tool and worked one side, then the other until it let go.
JP in NorCal
'98 993
PCA 1987
Old 06-13-2014, 05:19 PM
Update - done.
Okay thanks for the help folks, she's all done!
Old 06-13-2014, 06:00 PM
hda hda is offline
Has anyone ever installed a start button in lieu of the switch?
Old 12-02-2019, 01:26 PM
Science is NOT optional
rbogh901's Avatar
This is not uncommon and there may be threads. Let us know what you find.
PCA member since 1993
Old Yesterday, 08:39 AM
