-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   993 c2 fender vs turbo fender (http://forums.pelicanparts.com/porsche-964-993-technical-forum/460645-993-c2-fender-vs-turbo-fender.html)
911havoc 03-03-2009 12:55 PM
Does anyone know if there is a difference between the 993 c2 fender and the turbo fender?
Tom W 03-03-2009 04:00 PM
Yes. The C2 is less flared than the turbo. IIRC the turbo rear end is 2.5 inches wider than the C2.
911havoc 03-04-2009 07:35 AM
no worries, so the 993 c2s and the c4s share the same front fender as the turbo? I am assuming so. thanks
Tom W 03-04-2009 10:01 AM
The front bumper covers are the same size on C2 or "s" or turbo, only the rear is physically a different size. I have a Euro turbo front on my C2 cab. I am not positive that the quarter panels (wheel flares) are exactly the same.
silver911rdb 03-27-2009 05:22 PM
Fenders
The Turbo and C4S have more of a flare where the front fender meets the rocker panel. If you look closely on the turbo/C4S the rockers flare out more than a standard C2 or C4. So you can't use standard 993 front fenders on 993 Turbo's or C4S's. The rear quarters are also wider than a standard 993.
maccabi 03-31-2009 06:44 AM
I looked into this last year. Apparently the front fenders are the same on NB and WB cars. However, there is an additional part/flare that needs to be added to the fender for a WB at the bottom where it meets the rocker panel.
