Porsche Crest 90 964 Loud oil noise
I have a 90 964 and it has a loud oil noise inside the car comming from the oil tank area. I believe it is coming from the hose going from the thermostat housing to the filter along the wheel well. It sounds like a water fall. Has anyone seen this and is there a fix for it?
Old 08-11-2009, 05:59 AM
Is it after you have it running for a fe minutes?
If so it is just the oil warming up and stating to flow. Some are louder then others
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 08-11-2009, 06:02 AM
No it happens all the time
Old 08-11-2009, 06:05 AM
While driving or sitting still or both
2011 M3 4Door
Old 08-11-2009, 06:26 AM
you can hear it wile sitting but it gets even louder when driving. I know some noise is normal but this is way to excessive.
Old 08-11-2009, 06:43 AM
ok, while sitting in the car, can you turn the sterring wheel left and right , does the noise get louder?
Alos does the noise get louder with the RPMS are not ?
2011 M3 4Door
Old 08-11-2009, 06:57 AM
no change in noise with just turning the wheel at idle. only change is when rpms go up.
Old 08-11-2009, 07:04 AM
group911@aol.co's Avatar
Some of my 964's do it and some don't with my 89 being the loudest. I don't worry about it as I think it's just normal oil circulation through the oil tank.
Maybe the mount's / isolators weren't good enough??
Thanks,
Bob
group911@aol.com
Old 08-11-2009, 05:22 PM
mdowell's Avatar
Mine did the same thing when I bought it. The noise went away when I changed the oil. I wonder if the PO was not using as thick a oil as I am?
02 C4S
'78 911
'92 911 Cabriolet (Passed)
Old 08-12-2009, 06:27 AM
I think we are going to replace all the oil lines from the tank and the thermostat. they are all old and need replacing any way. we are thinking possably that they are hard and rubbing against the body making it amplified.
Old 08-12-2009, 08:29 AM
Most people pay extra for that
Thanks,
Bob
group911@aol.com
Old 08-12-2009, 09:10 AM
Tags
964 oil noise
