-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Cylinder Head Temp Sensor (http://forums.pelicanparts.com/porsche-964-993-technical-forum/472136-cylinder-head-temp-sensor.html)
Chas911 05-01-2009 05:50 PM
Hi gang,
Does anyone know if a CHT sensor can fail or partially fail without throwing a trouble code? I was so certain that was my problem, but even checking with a hammer shows no codes.
livesportm 05-02-2009 11:57 PM
Why do you think it has failed? Is it hard to start when it is cold?
Chas911 05-03-2009 07:52 AM
Yes, it is hard to start when cold and has a hesitation just off of idle. Then some days there is a short period when it is warming up that it runs great. Then when it reaches operating temp it has the hesitaion again.
I have cleaned the ISV. That helped some. I did the Air Flow Meter wiring TSB. That did nothing but needed to be done anyway. I changed the O2 sensor. That helped a little. Replaced a bad coil. That helped an amazing amount, but there is still that annoying hesitation that makes it not fun to drive.
Don Plumley 05-03-2009 11:41 AM
I'd bet $10 it is the CHT
livesportm 05-03-2009 02:35 PM
Can't say it will fix the hesitation but it should help with the starting. Its easy to swap and not expensive so its worth changing it.
Chas911 05-04-2009 08:33 AM
Yea, I'm thinking I'll just change it to rule it out if nothing else.
Thanks Guys
sml 04-13-2011 06:34 AM
Chas911 .. what was the outcome?
Chas911 04-13-2011 04:04 PM
It worked a little, but I still have a slight hesitation and when I start it from cold I have to start it at least twice before it will stay running, and even then it runs on about three cylinders for a few seconds. I am now suspecting maybe fuel or fuel pressure at start. That doesn’t work for the hesitation though. I’m wondering if maybe it might be plugs or wires so I’m going to replace those at my next valve adjustment which should happen soon. I also still wonder if it isn’t a vacuum leak somewhere but I sure can’t find one.
dlpalumbo 04-14-2011 08:22 AM
My car started much better after changing coils
sml 04-14-2011 02:26 PM
I have tried this ... problem still persists ...
- new ISV
- Steve Wong chip
- new coils
- new fuel filler neck & cap
- checked for vacuum leaks
- new air filter
- cleaned AFM
- fuel injector cleaner fuel additive
- new oxygen sensor
175mph951 04-22-2011 02:06 PM
you had a bad coil originally? ive seen bad coils damage the ignition control modules something you may want to check but doesnt sound like thats your problem, did you check the boot that goes between the manifold?
LUFTMAN 04-22-2011 02:12 PM
i have seen those cht sensors act up on a carrera 3.2 engine. i have a new sensor for a 964 engine for $50.00 if that will help you regards tom
