wonka
964 door mirrors repair
Hello, I want to remove the glass of the door mirrors so that I can have it repainted. Can anyone tell me how to remove the glass?
wonka
I meant I want to repaint the side or door mirror body. I have to remove the glass.
I beleive you fold the mirror down and slide a tab to one side, not the hole mirror just the glass, Kevin
There is a castellated retaining ring which holds the mirror glass to the hub. Access to the retaining ring is through a small hole on the underside of the housing. The ring can be rotated by using a flat bladed screwdriver through the hole and pushing the ring around (I think, anti-clockwise). The glass will then come out quite easily.
Regards Dave |
More info than you are looking for, but there are links to pics and instructions for removing the glass here:
993 Mirror Install
1990 Carerra 4 |
wonka
Thanks Gardoni and computamedic for the info. I was able to pop out the glass from the door mirrors. It was hard to do. I'll have them repainted soon. Best regards
Here a pixs of the 1991 964 Carrera2 Willie ![]()
