Twins are more fun!
JMA-RUF's Avatar
Ignition cable clips?
Guys, where can I get those ignition cable clips which secure the ignition leads to the valve covers via the existing nuts?
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 05-27-2009, 03:21 PM
Don Plumley's Avatar
This one?
Don Plumley
M235i
Old 05-27-2009, 05:43 PM
Twins are more fun!
JMA-RUF's Avatar
NO, not quite. There are individual clips... one for each lead, which secures the lead in place via a valve cover nut.
James
Carrera TT
Old 05-27-2009, 05:45 PM
I don't see it in the Porsche Katalog - just nuts and washers. My 993 has holders molded into the valve covers.
Don Plumley
M235i
Old 05-27-2009, 06:00 PM
If you mean Ignition Wire Clips, then check our host for: 964-602-559-00-M100 at: http://www.pelicanparts.com/catalog/shopcart/911L/POR_911L_ELignt_pg2.htm#item8.
Old 05-27-2009, 08:23 PM
Nice find!
Don Plumley
M235i
Old 05-27-2009, 09:01 PM
Twins are more fun!
JMA-RUF's Avatar
How do these actually secure to the engine?!?
James
Carrera TT
Old 05-27-2009, 09:25 PM
They use small screws. There are several threaded holes in the valve cover.
Old 05-28-2009, 11:45 AM
Take you time with these clips and they will last a lifetime. Tug and pull on the wires, toss the valve covers around and, like me, you'll be ordering a handfull of them. Slow and steady always wins the race as I keep learning over and over...
Old 05-28-2009, 12:51 PM
