Unhappy Help- Distribitor
Dear All
I am replacing my distributor cap and rotor. The Bottom rotor just moves and is not lock like the top distributor?
Andrew
Old 06-19-2009, 08:21 AM
kurquhart's Avatar
Sounds like the distributor belt is broken. This can burn a piston if the second distributor is firing, so don't start the car until this is fixed. You will also want to add the vent kit that will prolong the life of the replacement belt.
Kris
1990 C2
2005 CS
http://krisu.smugmug.com/Auto/Porsche
Old 06-19-2009, 09:16 AM
Does anybody know how often do we have to change the $7.00 distributor belt?
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 06-19-2009, 10:23 AM
mdowell's Avatar
Andrew,
Like Kris said, you should only need to replace the belt, not the whole distributor like the dealer would tell you.
Matt
Old 06-19-2009, 02:38 PM
Every 50k miles (80k km)
1991 C4 Coupe, Polar Silver
Old 06-19-2009, 05:01 PM
