Recreational User
Davie Boy's Avatar
964 Cylinder Leakage
I'm a novice here, so forgive me. Is the 964 cylinder leakage problem progressive or can it happen overnight? In other words, can you go from bone dry to rain in just one day?
'88 924S - Stone Grey Metallic
Old 06-09-2009, 11:45 AM
Don Plumley's Avatar
Rain usually indicates failure of a seal. So it would not happen overnight.
Don Plumley
M235i
Old 06-09-2009, 01:32 PM
Recreational User
Davie Boy's Avatar
That's kind of what I thought. I figured there'd be some warning signs.
Old 06-09-2009, 05:31 PM
Rouxzy's Avatar
If you're talking '90, 964 then there is no seal. It is metal on metal. Eventually they all leak. Porsche was doing a fix on these if if happened during warranty. The '91 came with a seal. My '90 engine had the update with the seal during rebuild.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 06-09-2009, 06:00 PM
Recreational User
Davie Boy's Avatar
Yes, it's a '90 964. But seal or no seal, would a heavy cylinder leak occur like this overnight or would it start slowly?
Old 06-09-2009, 06:44 PM
Send a message via Yahoo to FRED/LI
Do a search here or on the other board...there are multiple sources for your 'leak'.
Don't assume it's the cylinders yet. Could be the power steering pump seal at the camshaft, oil line, valve cover, chain cover, tensioner seal, and on and on.......
Fred '95 Carrera2. Previous: '69S, '79SC, '84Carrera, '90 C2, 20+ years and counting......
Old 06-10-2009, 04:07 AM
Recreational User
Davie Boy's Avatar
Actually... it's my mechanic that's telling me it's the cylinders. The problem is... I just spent a good chunk of dough having them repair several smaller leaks, i.e. valve covers, oil return lines, etc. When I got it back, the car was bone dry. About a week and maybe 40 miles later, I walked into the garage to see a good sized puddle under the car. It was leaking even heavier than before. I turned the car on, have my wife give it a little gas while I watched, and the oil came down like rain. I automatically assumed something had come loose or wasn't fitted right, and had it towed back to the mechanic. The cylinders was his diagnosis. I'm thinking "second opinion."
Old 06-10-2009, 10:06 AM
stevepaa's Avatar
I can not imagine how the top end seal would be suspect if the oil is pouring out. I suspect the oil ring in the passage way with the headbolts might be it. Or the valve covers are not fitted down tight.
Old 06-10-2009, 02:07 PM
