Venetian's Avatar
964 Oil tank drain plug?
A friend recently bought a 1990 964. He cannot find the drain plug on the oil tank?? Is there a different set up for draining the oil tank on the 3.6 than the 3.2 that I am familiar with?? Thanks.
1987 Carrera, Venetian Blue.
Old 06-24-2009, 04:39 PM
Should be same as my '92, you'll see the tank and oil lines in the rear passenger wheel well just in front of the tire, the plug is in the frame just below the tank.
Old 06-24-2009, 09:13 PM
Oracle's Avatar
The plug looks almost like a nut supporting the body skirt.. it's a few inches from the tire (you can't miss it)
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 06-24-2009, 09:25 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
its not actually on the tank. its on a plastic 'y'pipe piece that hangs down below the tank.
Old 06-26-2009, 09:59 AM
