964 fault codes
I plugged in a Bosch 9288 hammer diagnostic on my 90 964. I found these faults: HO2S and ECTS. Can anyone tell me what they are? Thanks.:)
I found the following:
ECTS = May be related to Cylinder Head Temp (Engine Cylinder Temp Sensor??) ECTS = Engine coolant temperature sensor - Only in water cooled cars HO2S = Heated O2 Sensor |
Thank you very much. If possible can you provide me with most of the fault codes of the 92888 hammer?
| All times are GMT -8. The time now is 03:32 AM. |
