-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   1991 carrera c4 window, heater issues- How do I close the window manually? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/495677-1991-carrera-c4-window-heater-issues-how-do-i-close-window-manually.html)
180mph 08-31-2009 01:21 PM
Ok I feel like my car has a ghost living in it. If you know what the situation could be please let me know. Heater is going on with switch in off position, when I start the car, If I turn the driver lights on, the heater settles down a little.????? wierd I know. Window switches will not work and the window is stuck in the down position so I need to get it closed --HELP. I know that there is a way to manually close the window but need instructions please please.
If anyone can help me asap I would appreciate it.
craig001 08-31-2009 04:21 PM
I have been out of my 964 for a while but if memory serves me - remove the tweeter near the top corner of the panel and there should be a fitting that a tool from the factory tool kit will fit into. I can't remember if it's an allen or twelve point though,
Check your owners manual to double check my memory.
zajo 05-23-2010 05:55 PM
I read in the owners manual that you use a tool provided in the toolbox. The instructions are, with the tool, to punch a hole through the speaker in the door, behind it should be a crank that can be turned with the tool. As far as I remember it wasn't the tweeter, it's the actual speaker in the door.
