Computer Display Dead on 964
The computer display which is on the tachometer has gone dead. No lights although the instrument itself works, and lights up when the headlights are switched on.
Any ideas on how to trouble shoot this? Is there a fuse? A relay? Can it be a loose connection? Where? Cheers, Nomi Ahmad 1991 964 Cab Tiptronic |
put in a new bulb the old one is obviously burned out
you will have to remove the speedo take it apart pry off the top PCB not hard order a new bulb from pelican |
| All times are GMT -8. The time now is 10:30 AM. |
