Are these Speedline, RH or ????
I am trying to get a positive ID on these wheels just by these pictures. They have the correct bolt head for a Speedline, but don't have the "SL" embossed in the bolt head. RHs typically have different bolt head style and a little dimple in them, so I am inclined to believe that they are NOT RHs. I can see a parting line between the outer rim half and center, so I am inclined to believe that they are really 3-piece wheels, but are they really Speedline? Can anyone help identify these wheels......
TIA! ![]() ![]() |
The extra lip looks odd for a Speedline
I am pretty sure speedline has their name etched on the lip, it looks like these have center rings? if so aftermarket but they do look like aftermarket, os on the 911 bbs and you will get your answer, Kevin
Definitely not Speedlines. Speedlines have 40 bolts securing the 3 halves together and have a polished outer lip with speedline for Porsche etched into it opposite the valve stem they also have the offset and width etched on either side of the valve.
Now I don't believe they are RH's since the early RH's had 38 bolts and the newer ones 40 and have a higher polished lip than the speedlines. I don't know what brand these are and there are many copies made of this wheel. The enters are some of the closest looking to the speedlines but the lip is all wrong. Most of the other brands I know of centers don't match as closely to the Speedlines. Real speedlines for comparison. ![]()
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
You are correct sir! They have been identified!!!! They are single piece, cast, Keskin KT2s...
