-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   How to check if used 993 has factory LSD (http://forums.pelicanparts.com/porsche-964-993-technical-forum/504798-how-check-if-used-993-has-factory-lsd.html)
rgv67 10-13-2009 03:11 PM
Hi everyone.
I just found out recently that my used ROW '95 993 C2 tiptro cab has the optional ABD. Most of the units I see being posted for sale having ABD also have LSD, how do I verify if I have LSD? I tried jacking up the rear tires and turned one side manually, other side stays still.
Appreciate your tips, thanks.
GregB7S4 10-13-2009 04:57 PM
Look at the white build sticker located under the front trunk lid (also located in the maintenance and warranty book)and see if it shows option 220.
Crimson Nape Racing 10-13-2009 07:20 PM
if the other side does not turn with it (in the same direction), then you do not have LSD or the clutch pack in it is completely worn.
rgv67 10-15-2009 04:20 AM
I don't have that sticker (used from Japan) and the other wheel won't turn so it means no LSD.
thanks so much!
