97 993 Front Seat does not slide fwd
My front seat, only slides forward on one of the seat rails. So when it is advanced forward it only slide along one of the two rails leaving the seat position at an angle. I am guessing that they may be two motors to slide the seat forward, and perhaps one is out? Anyone have a solution on how to fix? Thanks.
Old 02-20-2010, 06:34 PM
There is one drive motor with 2 drive cables for fore and aft adjustment, one for each side. When I got my car there was loose change stuck in the seat rail on the right side and that was enough to strip one of the cables.
If you remove the motor cover you will see the cables they just slide in and have a clip to hold the cable cover in place. They are just a square drive kind of like a speedometer cable.
Here is the part I needed:
Pelican Parts - Product Information: 928-521-252-04-M100
Good luck, hope it helps.
Old 02-20-2010, 07:39 PM
Thanks rsr91128, I will give that a try
Old 02-21-2010, 06:50 PM
