964 Random Stalling
Greetings fellow Pelicans;
Help me by discussing this scenario. Last night I drove home on the wet streets of S. California (10 miles via 405 Fwy), the car ran with no issues until I reached 1/2 mile from home, then it cut-out while driving 4 times within the last 1/2 mile from home (but was able to re-start immediately). There was no standing water that I drove through, did not have to use wipers home nor had any issues prior to these events. I have the under tray removed, could that has allowed excess water to get into something that would cause a stall? When I got home and garaged the car, I looked into the engine compartment and it was not excessively wet. I decided to drive it again to work today, the roads were wet, no standing water, no wipers either and it drove without any issues. What's happening here guys? Please share your thoughts and logical solutions. Thanks... SmileWavy |
DME relay.
Wet coil wires. |
It's hard to troubleshoot this kind of intermittent stalling issues. It is better just to wait for the car to bog down completely and unable to restart then troubleshoot it. The question is, is it absence of spark or fuel issue? Good luck! |
Do you think that having the 'under tray' removed could have allowed too much water into the engine compartment, thus causing a short? Last night I did the 'arching test' recommended and found no arching issues inside the engine compartment or from the bottom while misting up. Greatly appreciate the input. |
"bazar01" I'm going to look at the O2 sensor over the weekend, as I pulled it recently to install a 'cat bypass' and maybe it was not tightened enough :confused:. I thought I did but it has been mentioned here and on other sites, so I'm going to make sure of that, so I can eliminate that option.
Thanks. |
Everyone thinks I'm making this up, but I had a vacuum leak that caused intermittent stalling until I figured out what it was. Check the clamps and hoses around the ISV muffler just to be sure they aren't loose. Un-metered air was being sucked into the intake manifold causing hesitation, stalling, etc. My car has been perfect ever since I tightened up a few clamps.
Happened to me and all the while I was worried after replacing the DME relay all is well. I also do not think there is a permanent fix to the DME realy going bad. I just wonder how long does it take before it goes bad again. What causes this to go bad?
Ingo |
Are you still chasing this problem? A couple years ago my O2 sensor was loose and would unscrew itself until it fell out while driving. It did it a couple times until I finally took the wheel off and got a wrench on it. Every time it fell out the power dropped by what felt like 100 hp, it didn't like to idle at all, and the car was insanely LOUD. Just throwing that out as a basis for more 02 info. I've already mentioned to you that my stalling problem was related to a Wong chip upgrade that I didn't correctly seat into the DME under the seat. Keep in mind the stalling happened months after I installed the chip, so I never even thought to check it. I started tracking down the problem, and I thought it was my fuel pump... glad I didn't go through with replacing that! Fuel pump dead? Man graciously finds his limit. My car would stall, start back up, run strong for a while and then start back up. Eventually the frequency of the stalls increased... |
"911jettat" I am still chasing the issue and have not been able to duplicate the random stalling. I checked the O2 sensor and it was tight. I misted inside the engine compartment (top and bottom) and checked for arching but found. I even started the car, had my wife hold the accelerator pedal to keep rpm's over 2000 and then sprayed underneath the engine compartment with a hose but no stalling episodes at all. I purchased a new DME relay and if the cars repeats the stalling, I'm going to change it out and see if that solves it at that specific time. But until then, the car is running good and the random stalling has never been repeated to date... :confused:
Kinda frustrated but what to do... :mad: |
My '91 did this twice in its life. once was a sort of intermittant stumbling, my mechanic found sevral "loose" sparkplugs (ouch! I was sure I had set them in all perfect) problem solved. Once in was more of a random total electrical cut out, ended up replacing the "central electric"(fuse panel guts, pass. side under hood) never happened again. Although in hindsight it may have been just a loose harness plug under the panel, but changing the "central" cured it
Hopefully, your problem is gone for good. It may have been moisture related, but that also might have been a coincidence. The coils are hard to check with misting, since the coil covers prevent you from getting too close. If the problem re-occurs, and your coils have never been replaced,I'd start there, after trying a new DME relay.
I have this problem on occasion in the rain and when cold. I've replaced all the temp sensors etc. and it still does it. No fault codes show up. My mechanic thinks it might be an ignition switch problem but I am not sure. It definitely is temp related. It starts fine cold then after about a mile it just shuts off. Restarts right away on the starter, but won't refire by declutching . I have to turn ignition switch off and on again.
Has you airflow meter plug been modified per the TSB? I had a similar issue and found that although someone removed the wrap from the connector per the TSB, the boot was not wire tied and the wires were exposed. I would get random hesitation and cut off once in a while. After fixing the boot I have not had any problems since. Might be worth checking.
Thanks always... SmileWavy |
Try this link for information. If you do a search on 'air flow meter' on Rennlist you will yield quite a bit of information.
http://www.pcarworkshop.com/images/b/ba/24_x_1990_620590geolab.pdf |
| All times are GMT -8. The time now is 07:44 AM. |
