-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   removing rocker panel (http://forums.pelicanparts.com/porsche-964-993-technical-forum/528515-removing-rocker-panel.html)
inaminit 02-27-2010 04:11 AM
Hello-would like to remove the passenger side rocker panel cover on a C2 to get at the oil lines inside. Is there a trick to this? Where is the front fastener and how do you get at it? Thanks
pantera 03-01-2010 01:15 AM
This will be of great help.
Shark Fin Removal - Rennlist Discussion Forums
Regards,
Dan
inaminit 03-01-2010 01:39 AM
Heartfelt Thanks, Dan. That is just what I needed! I totally missed the post because they called it a shark fin, and I had never heard of that term before. Am I going to need some sort of glossary to survive here?
pantera 03-01-2010 02:05 AM
Your very welcome. No, unfortunately no glossary that I know of, its learn as you go.(edit: see if you can get yours hands on a PET CD. It will give you part numbers,pictures and desciptions) The Pelican group as well as Rennlist are a great group and a wealth of info. All you have to do is post your question and many will come to your aid.
Best of luck,
Dan
