question about 964 rear reflector panel
Does anyone know what the inner bulbs are for mine do not work, just bought the car and not familiar with it yet. I'm thinking tail lites. The outer lites are backup. Thanks for any info.
Old 03-17-2010, 04:55 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
on the tailights, starting at the outside corners, parking lights, then turn signal, then parking/brake light combo, on the center reflector its backup lights..
Old 03-17-2010, 09:06 PM
computamedic's Avatar
If you have the Euro reflector the inner bulbs are for the high intensity rear fog lights that are mandatory in Europe.
Regards
Dave
964 Register Secretary - PCGB
1989 C4 wide body conversion
www.964uk.com
Old 03-18-2010, 12:20 AM
Thanks for the info but I'm missing something. Next to my back up bulbs there is another bulb which is a single filliment 1156 style bulb. I'm still guessing additional running lites because they are ment to shine thru the red reflector lens. Anyone have any suggestions on what I can check to see why they don't work? Any other geusses on what they may be?
Old 03-18-2010, 05:23 PM
I told you what they are in the previous post - rear fog lights. The reason they don't work for you is that the US cars don't have a switch on the dash for them. The bulb will be a standard 21w single filament bulb and they would normally (in a RoW car) be switched via an additional switch on the dash with an orange logo. They will only operate when the front fogs (green logo) are switched on.
Regards
Dave
www.964uk.com
Old 03-19-2010, 12:04 AM
Dave +1. Fog lights.
Old 03-19-2010, 03:51 AM
Now I understand. Thanks for the info.
Old 03-19-2010, 07:02 PM
Newsboy's Avatar
You can convert these non-used lights to bake lights, by connecting them to your existing brake light circuit, I believe there is a DIY on p car.com.
Old 03-20-2010, 02:56 AM
