help
heater only works on cold move dial to hot fans shut off
power steering pump leaks at the sides
lights go dim and then ok well driving
Old 03-24-2010, 07:17 PM
What year, what model?
On the heat, your CCU might be bad
You need a PS rack
You may need a new alt.
Old 03-25-2010, 07:56 AM
computamedic's Avatar
Cabin fans shutting off when heat selected is almost certainly a problem with the rear blower. Check the fuse (should be a 30 amp part) and if OK, swap the oil cooler fan relay from the front fuse box to the rear blower relay in the engine compartment. Make sure rear blower runs when heat selected. CCU will turn off cabin fans if rear blower fails.
If the PS pump is leaking a new rack ain't gonna help. The pump can be refurb'ed.
Lights dimming and coming back on while driving is a sure sign of a bad earth. You need to check the earth straps to the body and the main earth to the battery. Clean and tighten them.
Regards
Dave
964 Register Secretary - PCGB
1989 C4 wide body conversion
www.964uk.com
Old 03-25-2010, 03:02 PM
i will try and its a 89 c4
Old 03-25-2010, 04:36 PM
thanks now got heat
Old 03-27-2010, 05:11 PM
and the diming lights is the rear fan motor
Old 04-01-2010, 01:35 PM
