impulse sender/ flywheel sensor
I was tring to replace the flywheel sensor in my 90 C4, naturally it was seized and would not come out. It ended up cracking and braking out the housing mounting arrangement for the sensor. Anyone ever have this happen to them? Will JB weld hold it back together
Roofbolter 1990-Carrera 4-Forest Green Metallic, SW chip, cat bypass, 18" twists 03 Land Cruiser & 93 Land Cruiser Romans 6-23 |
The broken pieces turned out to be from the mounting adapter, I orginally thought I had broken the transmission housing.
Insert Tag Line HERE.....
lucky you!
