e p slick's Avatar
A/C Relay Question - 993
Have fresh and functining A/C compressor + proper volume of refrigerant + lube oil. Also know that condensor fans are functionuing. Can only get 52 degrees at cockpit vent however (90 degrees ambient). Seems as if A/C relay may be cycling (if that makes any sense) since there is not a constant power feed to compressor spade connection. I believe that there are thermal switches in electrical system prior to relay so I would expect it to make sense to test them next.
QUESTION IS: where are they and how do I test them?
Appreciate any input since I am pretty lost at this stage.
EPS - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 05-08-2010, 12:55 PM
Hi Paul.
Glad to hear you got the 993.
Two things that could be doing it, high-lo pressure switch, evap core temp sensor.
Here is a link that got everything you need. What high/low pressures are you seeing at the compressor when it is running?
COMPLETE A/C Diagnosis - Rennlist Discussion Forums
Old 05-08-2010, 03:08 PM
38 degree difference is not bad. I don't believe these 36 degree reading at the vent, must be 70 outside.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-08-2010, 03:36 PM
e p slick's Avatar
Thanks for the advise.
I am getting closer. 35lbs and 250lbs. Three way switch seems to be functioning properly. Rennlist discussion was of very siginificant help.
Thanks again
EP Slick - Tucson
Old 05-09-2010, 04:54 PM
