undulating power
hi , got another wee question , in my 964 T if i cruise along at aroud 2k rpm and hold it steady there seems to be an undulation in the power/rpms ie goes up and down but only a tiny amount - its quite annoying when driving has anyone any idea what could cause this ? other symptons it would have is if you rev it from idle there is like a hiccup as the revs increase around 1-2.5k when blipping the pedal , also it seems to idle slightly low - 550-600rpm
ISV ? - could this cause both issues ?
any help greatly appreciated ?
cheers
Johnny
Old 05-18-2010, 04:01 AM
Manassas, VA
lucittm's Avatar
Johnny,
Try tightening all of the intake manifold nuts, that helped me once.
Also, it could be a bad O2 sensor, but those seem to fail rich and your symptoms sound like a lean condition. Finally, check your injectors with the six baby food jar method. If you don't know that method, just post again, many here can help you.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 05-18-2010, 04:17 PM
