Where are the Knock Sensors on a 993?
Hello,
i have an error code from the DME reading knock sensor 2. I guess it's the sensor itself, because a bad fuel would have trigger both sensors from each cylinders banks. The engine rattles at idle. I never changed one of those sensors and wonder were are they located, and how can i easily get to the bank 2 sensor? i guess i will have to remove the air filter assembly, and maybe the air intake distributor? any idea? let me know thanks Cedric SmileWavy |
Here's an illustration, it's right on top of the cylinder head. The workshop manual suggests reseating the connector to elminate contact resistance before replacing the sensor.
http://forums.pelicanparts.com/uploa...1275254245.jpg |
thank you for the illustration!
but how do you get there? i was thinking about removing the Fan assembly with the alternator to get under the engine shroud. What do you mean by reseating the sensor? |
Unplug the sensor connector, check connections, replug. I looks like you do have to get under the shroud, which is why you want to check the electrical connections first.
| All times are GMT -8. The time now is 02:51 AM. |
