-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Tiptronic Question - Acceleration Hesitation (http://forums.pelicanparts.com/porsche-964-993-technical-forum/553778-tiptronic-question-acceleration-hesitation.html)
cjoenck 07-17-2010 03:38 PM
OK, this is my first tiptronic so I have no comparison. When I floor it out of a standing start, I feel a hesitation for a second or so - almost the car is thinking if it should really do this... I know the 0 - 60 acceleration is about 1.5 sec longer in a tip than a manual but is this hesitation normal? Thanks.
LouZ 07-17-2010 05:34 PM
Under normal accel, the Tip is programmed to start out in 2nd gear. If you floor it for a quick getaway, there is a minor hesitation as the Tip downshifts to 1st.
You can do 2 things to have it start out in 1st:
...put it in "manual" and make sure that you drop it into 1st prior to accelerating
...select "3", instead of "D", this will have the Tip starting out in 1st.
