Kaboom
Upon start up, cold or warm, the right side of my intake plenum blows up with a big boom. Problem was intermittent in nature @ first, but has become more prevalent.
Fuel or ignition??? any input would be appreciated
1980 911 - Metzger 3.6L 2016 Cayman S |
lake wales fla
Check the drive belt in the dizzy
Banned
Valve adjustment, ign timing check.
When I numbered all the spark plug wires and reviewed the firing orders for both distributor caps, I found that the lower #4 & #5 spark plug wires got swapped somehow. Hope that solves problem
Good to know the cause of the problem.
To be continued:
Installed new NGK 5099 spark plugs to get a spark plug reading. Found the classic chocolate brown insulators as desired expect in #3, where that spark plug smelled like raw fuel??? Upon start up it ran for a while , but couldn't get to idle. Stall occurred and tried restart until the barn door assembly blew off, AGAIN ![]() Went to the POC race @ Fontana on Saturday to talk to the knowledge base available. Only 120 degrees with 165 asphalt temps, real passion for motorsports, OMG ![]() The tip I got was to suck on the vacuum line for the fuel pressure regulator and check for the presence of gasoline. Bingo, mouthful of gas. ![]() Question is sources, prices, and removal / install process for fuel regulator
Answer my own question to complete
Bosch 0 280 160 297 is NLA What's a purist to do with an 85-89 car??? Here is a better one, car is a bastard child anyway https://928motorsports.com/parts/fuelregulator.php
Check this out.
fuel pressure regulator fix
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
When the fuel lines got disconnected from the regulator, I found that the swaged end of one of the hoses was able to rotate. A little effort got the second one to do the same. replaced both pressure hoses from regulator to the fuel rail
Mg ,
Paul Mason is selling kits for 964 fuel lines , and I talked to him about sets for 3.6 conversions . Might be worth checking in with him as I can’t remember what he said . I think earomotive made I nice fpr I saw once ... And finally , My old grandmother used to say don’t put anything in your mouth and suck on it unless you want a mouthful of nasty stuff .. |
