AC switch problem
The air conditioning system seems to be OK as long as the AC switches are not touched on my 993. The air flow through the dash and bottom vents change to minimum as soon as either of the AC switches is pushed.
The compressor fuse and relay are OK. Additionally, everything was OK when the refrigerant was changed in the AC system. Maybe the control unit is failed? |
| All times are GMT -8. The time now is 09:43 AM. |
