Jeff Mohrlock's Avatar
Motor spins, won't fire
Hi All, I have a 1990 C2 with 38,00 original miles. Car has never given me any problems..UNTIL THIS MORNING! When I went to start it I noticed I didn't hear the "click" when I turned the key. The motor spins like it wants to start but does not fire. Seems that the "no click" and the "no start" have to be related, right? Your expertise and opinion is really appreciated as I am stuck....
I'll work 3 jobs to keep my cars
Old 11-03-2010, 07:02 AM
First guess would be the DME relay.
Old 11-03-2010, 10:11 AM
This happened to me a coupe of months ago when I drove my car to work and couldn't get it started at the end of the day. I swapped the DME and Vroooooom!
Old 11-03-2010, 04:42 PM
RETIRED
Joe Bob's Avatar
I have thread on this....you need to find out if you have spark and then test for power at certain areas. Most likely it's the DME relay.....but not always.
PM me if you need help.
2012 ML350 3.0 Turbo Diesel
Old 11-03-2010, 11:38 PM
If you don't have a spare DME relay, a triple wire jumper plugged to pins 30, 87 and 87b on the DME relay socket will simulate the relay, supply power to the fuel pump, DME and injectors. If the car starts, you have a bad DME relay. If it does not start, the problem is somewhere else.
The jumper is a test tool or a limp home tool and should never be used as a permanent fix.
Good luck.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 11-04-2010, 03:29 AM
S ECU Repair's Avatar
+1 for bazar01
Specialized ECU Repair
Porsche Bosch Motronic DME Specialists
Free DME Testing for Pelican Parts Members
www.ECUdoctors.com
1-800-328-1425
Old 11-04-2010, 08:55 AM
Cool
THANKS for the responses. After following the jumper advice the car started and I have ordered the DME relay from Pelican. I love this forum.
Old 11-04-2010, 08:49 PM
RETIRED
Joe Bob's Avatar
If the relay isn't it......which I hope it is.....have a digital meter ready. Mine needed it.
Good luck.
Old 11-04-2010, 09:04 PM
