-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   3.6 problem areas ? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/555678-3-6-problem-areas.html)
Drdogface 07-28-2010 08:35 AM
3.6 problem areas ?
I mistakenly posted a similar question on the 996 forum just recently...oops.
Just looking for info/experience from you guys re: issues that develop in 993 motors over time/miles. I'm buying one from perhaps the best known builder/shop in the Southwest but want to know what things to be aware of on a used (48K) 1995/993 motor. Leak down was 2 to 5% which I guess is good. One person said to beware of dist. drive belt. How do you know about the lower end or is that a problem area ?
Edit: I'm planning on a 95/993 motor but let me ask also if I should be looking at a 964 instead. I thought the hydro lifters and still OBD I was a good choice ?
I do not/will know track or Auto cross. Just drive for the fun...
What else need I know about ? ...uhh except the attention of the CHP.
aigel 07-28-2010 11:24 AM
The bottom end is a pig in a poke on a used engine, unless you can run it. Then oil pressure will indicate if anything is going bad. Also, oil analysis would be something to consider if possible on a used engine, if it still has some oil in it. I believe a couple of tablespoons would suffice.
HTH,
George
Drdogface 07-28-2010 11:37 AM
HTH,
George
Thanks George. I had heard about the oil testing. How long must it be run to have that be worthwhile ?
aigel 07-28-2010 12:05 PM
I am no expert but if you look at 993 reports, the average runs are about 2500 miles, so I would say that it is meaningful at about 1/3 that mileage. Say 800.
You may want to ask the experts at Blackstone Labs They also offer a fast turnaround kit "lemon-aid".
HTH,
George
