TARGAJACK's Avatar
For fadded taillights...
I was to buy a complete set of corners and center lights for the 993 and I tried the following with impressive results ( like new ) Nobody can say it's not new, even from 3''
Water sanded with 2000 grain
Applied Duplicolor Clear plastic promoter
5 coats of DUPLICOLOR TRANSLUCENT CANDY APLLE RED ( Air brush )
Rest for 24 hours
3 coats of Duplicolor top coat clear
Rest for 24 hours
3M ( 3 stage coumpound )
3M polymer wax until mirror finish.
Look at the results...
TargaJack
1995 - 993 Coupe
1986 - 911 Targa ( Sold )
Old 02-24-2011, 05:27 PM
Oracle's Avatar
Wow!! That looks new!
Awesome work!
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 02-24-2011, 09:10 PM
Old 928 Guy
surfdog4's Avatar
where did you get the paint?
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 02-25-2011, 06:59 PM
TARGAJACK's Avatar
From a Duplicolor retailer N.AP.A . auto parts, they ordered it.
Good luck
TargaJack
1995 - 993 Coupe
Old 02-25-2011, 07:41 PM
DANTHEBUGMAN's Avatar
Would you mind sharing what your products cost you versus a replacement? My first 993 is being delivered this week and, judging from the pictures, this may be an issue I will have to deal with. TIA
Old 02-28-2011, 07:22 PM
TARGAJACK's Avatar
There you go, if you are DIY guy, you'll probably shoot it yourself as I did,
Here are the average costs
-Water sanded with 2000 grain.....5.00
-Applied Duplicolor Clear plastic promoter......12.00
-Water sanded with 2000 grain until no orange peel
-5 coats of DUPLICOLOR TRANSLUCENT CANDY APLLE RED ( Air brush ).....30.00Rest for 24 hours
3 coats of Duplicolor top coat clear.....30.00 ( 1 quart )Rest for 24 hours
3M ( 3 stage coumpound ) ...... Already had it, but it's about 15.00 / grade
3M polymer wax until mirror finish. 20.00 ( It's the Mcguiars wax )
Total material.:: 100.00
Coumpound.:: You can use a standard rubbing coumpond so add 15.00
Rent of an electric low pressure gun.:: 25.00
Under 150.00 if you have some of the stuff for regular maintenance. ( wax-coumpound ..)
The red marked items are what I bought.
Thank you
TargaJack
1995 - 993 Coupe
Old 03-01-2011, 01:30 PM
Metal Guru
911nut's Avatar
Meguiers plastic cleaner and plastic polish worked for me. I wouldn't have the 'nads to take 2000 grit sandpaper to my lenses.
I painted mine with red paint around the edges along the surface that seals with the gaskets. The red got reflected into the rest of the taillight, making it redder. In doing this rather than painting the entire lens, I was able to preserve the white area of the back-up lights and the amber turn signal lights.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 03-01-2011, 03:16 PM
Oracle's Avatar
niice... just the edges eh...
What paint did you use?
-Oscar Wilde
Old 03-01-2011, 08:30 PM
Metal Guru
911nut's Avatar
Originally Posted by Oracle View Post
nice... just the edges eh...
Just some leftover red Testors modelling paint.
Paul B.
'91 964 3.3 Turbo
Old 03-06-2011, 07:02 AM
