Architecture & Porsche's
in/out play on my distributor shaft?? 965
I changed out my cap/rotor tonight because they were old & I'm having ignition issues with my car.
having intermittent ignition failure that's sometimes, there, sometimes not in more than one cylinder. My cap/rotor demonstrated unusually high wear, so I changed them out. Upon pulling/pushing the rotor on, I noticed that the shaft where the rotor seats has about 3/16 to 1/4" of vertical play. Im suspecting that a bearing/bushing internally has failed to allow this not in/out play. As well, it stays either pulled out or pushed in and I don't know which way it's supposed to be, but I figure the shaft is NOT supposed to be "in" where the contact between the cap & the rotor might be extremely weak since the spring-pin in the cap only has about 3/16" of in/out play as well.
Thoughts??
[/I]
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 08-17-2010, 06:13 PM
Usually the busing goes out and causes wobble affecting dwell (not an issue on 965)
I don't think the in/out is too much to worry about..I could be wrong
A while back i traced down a nasty ignition issue caused by lack of ground on the aluminum plate that holds all the relays ect on the drives side of the engine bay - I added additional ground
I have an extra ez69 and coil if you want to change them out to check
have you checked the flywheel sensor connector ? have you ever replaced the flywheel sensor?
Old 08-17-2010, 06:41 PM
Crap, swapped on a '94 3.6t distributor: had to re-layout the wires as the distributor & cap are rotated 90 degrees from a 3.3 turbo: wtf did they do that??
Anyway, runs, but my intermittent problem exists! Ultra week/failing ignition & lots of louder (than normal popping) in the exhaust on decelleration. I'll have to check the coil, ignitors, crank trigger (oil on it???): anyone have other ideas??
when the issue presents, it's not just one cylinder: it's more like 1,2, or 3 at a time as the car barely runs, barely accelerates, stumbles, then clears right up.. does it hot, cold, idle, cruising, uphill, downhill, etc: there's no specific time it does i.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 08-22-2010, 11:54 AM
