resurfacing my 3.6 to 3.8
I'm fixing the oil leak of my 964 but checking inside engine I found cylinders and rings are over the recommended end gap limit.
It's possible to resurface the 3.6 cylinder in order to use a 102mm JE ovesize piston and rings and increase to 3.8? I am using the same manifold but a better BCM cone filter and headers and exhaust system. Also performance chip This cuestion goes because the higher p/c 3.8 cost vs 3.8 JE pistons Thanks JC |
It's working amazing with the 3.8 l nikies on my 964.
Add vertex chip, schnell exahust double system and cone filter thank you for the help |
3.6 to 3.8 upgrade
I bought a 102 mm JE pistons and LE cylinders to upgrade my 964 3.6L to 3.8L, put the vertex chip, cone filter and schenell x pipe (one oxigen sensor) and believe me it's an amazing change. I am using motul 7100 oil 20W50 100 % synthetic for 4t motorcycle api sg,sh,sj,sl. going to 7000 rpm with no problem
http://forums.pelicanparts.com/uploa...1298212102.jpg http://forums.pelicanparts.com/uploa...1298212139.jpg http://forums.pelicanparts.com/uploa...1298212227.jpghttp://forums.pelicanparts.com/uploa...1298212689.jpg |
| All times are GMT -8. The time now is 05:27 PM. |
