964 C4 lt wt manual differential control's
I have long been curious about the manual controls that Porsche put in there Light Weight special C4's and offered to some of there race customers and was hoping for some input on how the early C4 drive train works and if I might be on the right track.
I used to think the special adjustment system was something very special and complicated but studying the picture of it below I am thinking it might not be that complicated and could be copied relatively easily. I suspect the C4 diffs have a slave cylinder on them that takes pressure from an ABS style pump and valving controlled by a special ECU. Looking at the picture of the C4 lt wt's system it looks to me like it is two fabricated manual adjustor's that probably have a master cylinder of some type bolted to the back of each of them. Then, with adjustment the master cylinder would pressurize the slave cylinder at the differential and effect the level of lock up. To give the driver some form of reference it also looks like they plumbed in two 25 bar pressure gauges so it is known how much adjustment has been applied to each diff. If this is so and someone just wanted to, why couldn't one even just fabricate and replace the slave cylinders with a mechanical adjustment at the differentials and mechanically fix the amount of lock up for a track car? Dose this make sense? Any input appreciated as I am not very schooled in this system. http://forums.pelicanparts.com/uploa...1286207952.jpg |
It looks like I got it right. Following is from another thread.
Dose anyone reconize the master cylinder like is it from the clutch, brakes or something else? Quote:
Has anyone done this to his/her 964 C4? I would be tempted :-)
| All times are GMT -8. The time now is 08:41 AM. |
