993 cold storage......
Hey,
Does any one know how I can prevent the rusting of my rotors as well as is there anything special I should or could do to ensure a successful exit from winter hibernation. All I have done so far is change the oil/fill fuel tank and add Stabil/put battery on charge maintenance and the unsprung weight is unsprung with the car on stands and car cover in place. Thanks all M- |
gduke2010
Sounds like you've got your car ready for storage. You really, don't need to do any more. Always good to use Stable while storing, Also, a battery tender will keep your battery for going dead during the winter.
Gary |
Now in 993 land ...
Ride the brakes a bit before driving the car to its resting place. This will make the disks toasty and they will have no moisture left on them to create surface rust. If it is stored in a dry place, the rotors should not rust. Even if they do pick up a little rust, the first time you press the brakes in spring, they will be clean again.
George |
you guys should move to Arizona, its the perfect time to drive out here
84 930 Slant 15 Sonata 2.0T 08 Ram 1500 15 Ram Eco Diesel |
Just a suggestion: You don't have to put the car on jack stands. If you pump the tires up to about 50 lbs and let the car sit in tire cradles or on a thick piece of carpet, you'll be fine. If they flat-spot a little over the winter they'll get round again after about 1 mile of driving. If you really want to elevate it off the floor, you really should put the stands under the suspension. The suspension is designed to hold the weight of the car. Unsprung weight doesn't mean it needs to be "unsprung" during storage.
Cheers. |
You should pump the tires up to 59PSI (according to owners manual), but you don't need to worry about flatspotting unless you have steel belted radials. Nylon/Kevlar belts have no permanent memory and so will not remain flatted. Don't sweat surface rust on rotors, this will come off the first time you apply the brakes, just like when you wash the car. Cheers! |
storage
Thanks guys and down she comes. I guess I was thinking old school when getting the car off the ground. Good advise on the exposed rods and will decompress the suspension and overinflate the tires tommorow.
Cheers, M- |
