GR8BRIT's Avatar
964 Heater Fan Stops When Climate Control Turned Up
When I turn the climate control temperature above the coldest setting, the fan stops blowing air. If I turn it down to cold, the blower starts up again.
does any one have and idea where to start?
Old 03-31-2011, 08:38 PM
trak ratt's Avatar
Had a similar problem that ended up being a blown fuse on the panel in the engine compartment.
Old 04-01-2011, 06:04 AM
Manassas, VA
lucittm's Avatar
Which fan, I think there are, like 5 of them...
Some of them can be connected backwards (polarity-wise).
1991 964 Polar Silver Metallic Turbo Coupe
Old 04-01-2011, 08:38 PM
PRO Motorsports
Tyson Schmidt's Avatar
The front blowers run full for venting and A/C, but when you ask for heat, they back off and rely on the engine compartment blower to do most of the work.
So my bet is that your rear blower failed, or the fuse is blown.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-02-2011, 05:58 PM
