930 Clutch Disc with LWF - Does it work?
Getting ready to do a clutch job in my 91 964. I want to go the LWF way on a reasonable budget. I happened upon a 930 clutch disc in pretty good shape. This is a 240mm disc with 6 springs. It is similar to the 4 spring 996, but not exactly the same.
Has anyone used the 930 disc with a LWF and 993 PP (964 part number)?
Thanks for any insight.
Old 01-11-2011, 09:58 AM
I am gathering the parts to do the LWF as well . While reserching this I discovered the 930 and 964 both use a 240 mm disc and I believe the spline count is the same also. I would think it would work but someone here might actually have done it
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 01-12-2011, 04:25 AM
