964 struts on 993????
I found a pair of adjustable front struts with a 964 number on the rod boot.
Do these fit on certain 993s ???
Old 01-30-2011, 06:37 PM
PRO Motorsports
Tyson Schmidt's Avatar
They will fit if you open up the lower holes on the struts to match the bolt size of the 993 wheel carrier-to-strut attachment bolt.
I installed 993 spindles on my 964, and kept my 964RS stuts. That was the only mod necessary.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-31-2011, 12:46 PM
OK, Thanks.
Apparently, the rubber dust boots on the factory 993 struts have 964 part numbers unless someone swapped them.
I found the 993 Monroe part numbers after I removed the springs.
Old 01-31-2011, 04:23 PM
PRO Motorsports
Don't waste your time with the Monroes. They are shot by about 40K miles.
2004 GT3
Old 01-31-2011, 06:39 PM
