Input Shaft Seal
Hello guys,
So I tried to remove the seal from the bell housing but it just hard to come out and all I did was making some mess. I was very careful not to damage inside the bore so it's still clean with no scratch. I just cannot grab the small piece in the tight spot. Please give me some idea to take the ***** out. Thanks in advance, BW :) |
Hey BW, the seal is way deep inside the housing so it's going to be a little tough. Have you tried a curved pointed pick tool with a handle like a screw driver? That's what I used. You can also drill two small pilot holes and screw in two metal screws and pull the seal out with two pairs of pliers.
I am ready to put the engine tranny back in this weekend. Good luck. |
Yeah, I will get the curved pointed pick tool and give it a try. Now I think I should have gotten the special tool in the first place since they have a good deal on ebay. BW :) |
Finally out!
After about 90min of bout, the ***** finally came out. I used a pair of needle nose pliers. Once I grabbed a tiny part of metal portion of seal, I pulled it with all my strength. It had finally popped out in my 3rd pull.
I will gladly pay an extra for the special tool next time. Pardon for the ugly picture. Just for the record... Thanks :) BW http://forums.pelicanparts.com/uploa...1297907420.jpg |
Poor oil seal, it took a lot of stabs and beating. :D
Mine only took one stab and it pulled right out. |
| All times are GMT -8. The time now is 05:59 AM. |
