Send a message via AIM to Mike Hall
92 964 rear frame rail pictures
I just bought a 92 964 C2 which has some low speed crash damage to the drivers side frame rail and possible a little to the passenger side rail. Does anyone have any good close up pictures that I might use to compare to my cars rails to see what all is damaged and if possibly the passenger side is good and straight? I know the drivers side is buckled a bit just in front of the shock power being it is bulged out at the bottom towards the tire a little. Other than that I am not sure if there is anymore damage so, some good pictures would be a huge help for comparing.
On another note, does anyone have body dimensions for a 964 so i can measure off some points to check the suspension points?
Mike
Old 02-24-2011, 06:57 PM
