One Hi Beam not working
One hi beam doesn't work, both low beams do,,, Bulb? thanks! Bart:confused:
What year 911?
Have you checked the fuses in the trunk? |
1991 964 C2, original, no, but wouldn't both hi-beams not work if it were a fuse?
Oops, checking the fuses is my first reply to most electrical issues. Sorry about that. I would say the bulb needs replacing. |
Got it! NAPA BP9004... just replaced them both and everything works just fine!
Thanks!~ |
Just ran into same issue. Replaced my turn signal switch (needed replacing) and both headlights. Switch works great, lo beams work great, but one hi beam is not working. Any other thoughts? Really appreciate it.
| All times are GMT -8. The time now is 10:55 PM. |
