964 induction system question
does a 964 engine have only a two stage throtlle body ? or does it have a valve that opens at a set rpm from a vaccumn signal?
2006 Cayman S 93 RS America white(now living in Arizona) 1974 911S/CARRERA (now living in Australia) Livermore Ca. |
The latter - the resonance valve inside the intake piping opens at 5500 rpm
thanks shamus
early used w/ aluminum manifolds ![]() late used w/ plastic manifolds ![]() a different question is the intake manifold, which has dual geometry's controlled by 2 resonance flaps. The resonance flaps are are activated by the DME via a vacuum operated electronically triggered solenoid after reaching 5500rpm, then close when the rpm drops below 5400. Additionally the flaps are activated briefly each time the ignition is turned on.
Carmagic.us
I have some question: I have the plastic manifold, and the solenoid is not operating when the ignition is switched on. The green/black wire has 12V when the ignition is on. When I connect the gray/white wire to the ground it operates. Could the issue be in the DME ?
Also from what year was the plastic manifold used, my engine is supposed from a 1990 car. Thanks for any info on that.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
