How often to change distributor/rotors?
Maintenance schedule says plugs every 60K, but what about other tune-up parts like the caps and rotors? How about spark plug wires? May do a clutch in 10K or so and it will be easier to access this stuff obviously then. Thanks!
I changed my plugs at 60K, even though they looked like new. I didn't change my caps or rotors, they looked fine also. At 60K, you should think about changing your distributor drive belt.
Coils, are also fairly inexpensive. Wires are expensive, and I wouldn't change them, unless you are having problems., leaking spark etc... |
I would do the wires when the engine is out unless they look pristine and are less than 5 years old. Yes, they are $ but it is a lot more hassle to try to change them with the engine in the car. I would also worry that with the twin plug, you may not feel a bad wire in the performance of the engine as easily as on a single plug ignition system.
George |
Drop the motor and do the clutch and all the sparkplugs, dist. caps/rotors and dist. drive belt. The pass side front sparkplugs are a b_tch with the motor in the car. I did this exact process 2 years ago. Also, bleed the clutch slave cylinder before you install the motor completely.
Awesome stuff guys, thanks
| All times are GMT -8. The time now is 01:27 PM. |
