Side window trim removal
Hi all,
I'm preparing my car for a respray and I was wondering what's the easiest way to remove the lower window trims? Or can you loosen them enough to raise them a bit?
Old 02-24-2011, 10:50 AM
I just replaced the driver's side black metal trim (under the quarter window). The trim piece is held in with 5 screws and some sort of sealant. In order to get to these screws, the window must come out first...
Andreas
1995 993 Coupe, Polar Silver / Black
2014 Audi A4, Monsoon Gray / Black
2002 Toyota 4Runner, Dorado Gold
2001 Toyota 4Runner, Dorado Gold, 604,XXX 1-owner miles
1998 Toyota 4Runner, Oxidized, 5-speed
Old 02-24-2011, 02:05 PM
That's what I was afraid of . Thanks for the tip!
Old 02-24-2011, 11:33 PM
Okay, I figured out the rear quarter windows and I've gotten to the doors now. Getting the door handles off was something of a challenge and I'm not sure how I'm ever going to get the black plastic lock cover back in there ever again .
Anyway, it's not very obvious for me how to remove the exterior door trim (the one between glass and lower door) without damaging it. Any tips for that?
Old 03-19-2011, 09:49 AM
Hah, the door trims were somewhat of an anticlimax, they're not hold on by much of anything. For archival purposes:
1) Lower the window
2) Wedge the trim up with suitable tool, it should come up easy:
3) The trim is attached to the door only with bunch of these spring pins:
Old 03-22-2011, 11:02 AM
