Brake Fluid Guru
Shock testing in Denver, CO
Can anyone refer me to a place here in Denver that can test my Koni shocks?
TIA
Michael
Old 03-23-2011, 09:12 AM
Michael, By this do you mean on a shock dyno?
James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 03-23-2011, 09:29 AM
Brake Fluid Guru
Frankly, I don't know. I have a pr of Konis that came off a car that had an engine compartment fire. The shocks clearly received some of the heat. Both shocks still have resistance to compress and are slow to rebound. I have put both on a scale, compressed the shaft and watch the weight reading. They both appear to be working about the same, however I know its not just a function of the weight on the shaft but the speed and I have no way to test for that (that I can think of - I'm open to suggestions)
There is one place that can test I was referred to however it will take them 2 weeks just to test. I'm hopeing to find someone local that can do a quick and simple test to tell me if their ok or need to be rebuilt.
Suggestions?
Michael
Old 03-23-2011, 09:42 AM
Michael, have you tried these guys?
Leary Racing Products
James
Ayrton Senna
1993 964 RS
Old 03-23-2011, 09:45 AM
Brake Fluid Guru
Yes, but they need 2 weeks just for a test and then can't rebuild them if necessary. In that amount of time I could send them to Koni Truechoice, have them rebuild and on their way back. Looking for someone that can just do a (quick?) test and give me the scoop.
Michael
Old 03-23-2011, 09:47 AM
Hmm, that's going to be tough, seeing as we are in the beginning of racing season across the country so most places are pretty busy now.
Personally, I would not run them until they are rebuilt. Heat can do bad things to dampers, especially the seals.
James
Ayrton Senna
1993 964 RS
Old 03-23-2011, 09:50 AM
Brake Fluid Guru
Its beginning to look like they will have to go to Truechoice.....
Michael
Old 03-23-2011, 09:51 AM
Brake Fluid Guru
FWIW, I did just find a race shop with a new shock dyno and that can get at the shock PDQ. And they can rebuild if necessary. All within a few miles of my place.
Michael
Old 03-23-2011, 11:07 AM
group911@aol.co's Avatar
Are you going to say who they are?
Thanks,
Bob
group911@aol.com
Old 03-23-2011, 07:36 PM
